A receiver will draw some power even when there's no signal. This varies a lot. Call it 50 watts, but it could be more or less. A budget receiver with no video processing or any other fancy circuitry probably is less than 50 watts when sitting idle.
A receiver will start drawing more power as you raise the volume level. Some receivers will list power consumption figures.
A low powered receiver might have a max power consumption of 300 watts. A more powerful receiver might have a max power consumption of 1000 watts. But these are max's which you would be highly unlikely to hit.
Under "normal" needs for music, you probably draw less than 5 watts / channel. For two channels, and 50% efficiency, you need under 20 watts just to run the amp.
I would figure, for normal use, a budget receiver should draw under 100 watts, but that's a guess.
