I'm running power to my front projector with rubber insulated 12ga 3-conductor wire similar to this . I'm ceiling mounting the projector and would like to run both the signal cables and power cable through the extension tube on the mount. Is there a way to shield the power cable so that I don't get unwanted interference with the signal cables? I was thinking of running the power inside the tube (aluminum) and wrapping the signal cables around the outside to try and keep them as nonparallel as possible. Any ideas?
David
David
