1 - 4 of 4 Posts
from time to time i get this wave from the bottom of my tv and usually goes to the middle and stops. i was wondering if this a power issue. i have a new 60 inch plasma, xbox360, ps3, a pioneer elite receiver , sat tv hooked vup....just wondering what this is. all my components are hooked up to a monter surge protector..would a power center make a difference? thnx!
.. have you tried by-passing the protector; tv/satellite directly into outlet.
add: might try disconnecting other components also; plus using another HDMI cable or even component cable to TV.
plus: keep TV unplugged for awhile.
1 - 4 of 4 Posts
