Hello
I'm running Windows XP as a server/HTPC and would like to turn it off when not using it. The computer is not easily accessible so I would like to know if there is some way to turn it into s3 or s4 from turning off the main power I mean the 220V or 110V depending on where you are living. The PC should of course still have power to go into s3/s4 (and stay there for s3).
So I'm thinking is there perhaps some weird USB adapter or LAN for this that enable me to use the wake on lan or wake on usb function?
Am I missing something are there better ways to save power when not using the server/HTPC?
Thanks for your advice
