It is against electrical code to run a power cord or extension cord through a wall. You need cut a 1 gang box into the wall behind the screen and run romex from that box through the wall to a nearby outlet and tap into that. It is also best to install a recessed clock outlet in your 1 gang box because standard outlets usually don't allow enough room for your plug behind the display.
