I currently have (2) PSA V1812 subwoofers in the screen wall facing out into the room and (1) V3612 behind the 2nd room facing forward. The issue is the V3612 is close to the 2nd row and it really shakes the seats.
Would it compromise the sound, or cause any issues if I turned it so that the woofers are firing down into the riser?
I would raise it up a few inches with some foam/rubber squares.
