OK, so Im hoping someone on here really knows their amplifiers and can help me with this one. In summary, is there any power/current advantage in running a multichannel amp with only two channels, as opposed to running the two-channel version of basically the same amp?
Specific example... I want to get a parasound hca-1000a for my mains. However, the multichannel version of this amp (basically,) the hca-1205, has twice the power supply VA and over twice the total capacitance, which would be expected since it is meant to drive 5 channels instead of 2.
So my question becomes, if I only run 2 of the 5 channels, is this power supply potential and capacitance going to be distributed evenly to just the 2 channels being used, or is it pre-distributed to all 5 channels? If so, it seems this would be a better performing setup, all-else being the same. However, both amps have the same per-channel current rating, so its seems this isnt the case.
The 1205 costs a lot more used than the 1000a, but I dont mind to spend more up-front and have the additional potential. I do not plan to ever run more than two channels from it, as I already have my desired setup on my center and rears now. I only need two more channels.
Thanks in advance!
Thanks in advance!
