I have some questions I hope you all can help with quickly, as my window for doing my new basement's electrical is nearly upon me.
I plan to have two tray ceiling areas, each rectangular, with crown molding that has color-changing LED strips installed behind the molding. They've very close in size, each of the two areas totaling about 50 linear feet in perimeter. So let's use that as our measurement.
What I'm trying to confirm are three things:
Checking #1...The RGB strips I'm looking at are 7.2W / meter. 7.2 x 15.24 M = ~110W per crown zone = 220W total (if every LED is on full). Is that right?
The LED strips I'm looking at say that no individual LED should be over 120" from the power input line. So, to cover 600 inches worth of LEDs, I think I'm going to have to run three 4-conductor wires (because this is RGB) from the power supply to each crown zone -- so I can power three "groups" of strips from the middle, no leg of any group exceeding 120". That's a lot of wiring: 6 runs total, 4 conductors each. Does this sound right?
As for #3...I plan to have a switched power outlet in an inconspicuous location, and mount the 12V power supply there. Then I'll run the low voltage lines inside the walls to wherever they need to come out behind the crown to power the various segments. My question here is: what wire should I be using to do this? Based on Googling around and playing with some voltage drop calculators, it looks like I need to use 14 gauge romex, because my runs will be anywhere from 5 to 20 feet. With RGB LED controllers, can I use standard 14-3 electrical wire (which would also have a ground wire)?
Does this all seem right to you? Is there an easier way to do this? My calculations so far seem to result in a lot of separate wire runs (to support no LED strip being over 120" long).
- How much power do I need, total?
- What's the best way to wire these up to minimize dimming/voltage drop?
- What kind of wire should I be running inside the walls for this low-voltage project?
