Status
Not open for further replies.
1 - 13 of 13 Posts
I did a search on both headings but I didn't find the information I was looking for...
I'm in the market for a power supply for my home theater. I previously had a Monster HT 5000, and I may get another one, but is there another unit/ brand out there that is similar. I need at least 10 outlets. If anyone could drop a name or two I'll research it.
Just plug a power strip into the conditioner. That will give you all the plugs you need provided you don't draw too much power.
Anyone want to offer their opinion on a conditioner for me/us?
It's the ART PS4X4 for $98.
http://www.allprosound.com/catalog/p...asp?fprodid=89
"Built into the PS 4x4 is a surge and spike protection system, designed to protect powered equipment from harmful electric surges and spikes. The unit also has RFI and EMI filtering, a 15 amp breaker, and a total power capacity of 1800 watts."
Thanks a bunch.
Discussion Starter · #7 ·
Thanks for the link Toxarch, I like the looks and functionability of that unit.
I've now modified my setup to need between 8 & 10 outlets so it may fit the bill too. The price is certainly right!
So I was looking around that website a little more to see if they have one without the lights since I don't REALLY need the lights.
I found the ART SP4X4 which has the same features as the previous one without the ammeter and costs $78. It still has the voltmeter and lights.
http://www.allprosound.com/catalog/p...asp?fprodid=80
And I saw this one (ART PB4X4) that appears to have the same protection as the first two without the meters nor the light. It's a plain jane model for only $38!!!!
http://www.allprosound.com/catalog/p...asp?fprodid=86
For $38, I could order two for the amps, one for the other equipment, and one for the projector. That would be 4 conditioners for under $160. Anyone want to point out why we shouldn't be considering this model? I don't need the voltmeters and lights.
Check out Richard Grey Power conditioners at MCIsytems.com
No comments on the ART conditioners? They also have ones with digital volt meters and ammeters on the front for a little more $$.
I'm going to order two of the $38 ones for my two Parasound HCA-2205AT amps (5 channel x 220 watts @ 8 ohms each) and give them a try. There is a local music shop that carries them, but they cost $59 retail. If they work good on the two big amps, then I will order two more for the rest of the equipment.
Well, I got the 2 ART power conditioners in today and connected each to the two amps I have. They handle the amps fine, but did not get rid of the noise I was getting through the amps. I'm beginning to think there might be a problem with the one of the amps. Either that or I need to do some wire management in the back of the rack. Each of the amps have dedicated 20 amp circuits. The main thing I was trying to get rid of was noise that comes through the speakers from the Grafik Eye dimmer. The GE has its own circuit and has already been replaced.
1 - 13 of 13 Posts
Status
