Found a solution....the MS has a 18VDC output...with the use of a DC-Passing splitter I am able to get power to the amplifier.
I connected one of the splitter outputs to the DC Output of the MS (which sends 18volts to the antenna amp, exactly what it needs). Connected the amplifier/antenna to the input of the splitter. The second output of the splitter runs into the MS Antenna input.
Thanks to the diodes in the splitter, the power is not back-feeding to the second output.
So..anyone need a Channel Master Powersupply
