Status
Not open for further replies.
1 - 3 of 3 Posts
Have a little problem with PowerDVD...
The Radeon 9700 Pro (Catalyst 3.2) is not recognized by PDVD (shows Videoaccelerator: Unknown in info-tab).
And now the strange thing: On a second mashine with identical softwareinstallations and win xp PDVD works fine. Only difference: the mainboard (ASUS P4T-E is okay, ASUS P4P-E = Problem)
Someone with an idea?
I have a P4PE and ATI AIW9700. I dl'ed the latest patch today for Power DVD XP. Everything works fine. EXCEPT copyrighted DVD's (store bought) played from my Sony DRU-500AX give me a message
Error Code: F4D41436
The TV Out port of your display card is not working properly.
This copy protected disc can not be played when the TV out function is enabled.
Next Step...disconnect the dongles try again, or else roll back to prev. ver.
The problem with this video card is that the HDTV out isn't run off the monitor out (DVI) but of their own "media jack". I assume you're card is not an AIW and doesn't have this crazy jack though.
I don't know why I insist on having the latest ver. of everything when it works fine as it is.
1 - 3 of 3 Posts
Status
