Status
Not open for further replies.
1 - 1 of 1 Posts
I downloaded and installed the latest update to PowerDVD (the 0324 patch). Once I did that, I noticed that sometimes I would get harsh crackles and clicks during DVD playback. I isolated the problem to be coincident with my executing YxY commands (I use YxY to fit 1.85 aspect ratio movies perfectly into my 16:9 screen).
My solution to this problem was Control Panel - Sounds - and to select the sound scheme which was "No Sounds". This prohibited Windows from sending clicks and other sounds to the HTPC and made this problem go away. Now, I have no idea why this problem first manifested itself with this most recent update, but that is just how it turned out.
Cheers,
Bernd
1 - 1 of 1 Posts
Status
