Joel,
If you are defining a new resolution from scratch - 1024x576, then you have to do all the math.
Since you want a 60 Hz vertical refresh rate - you have to ensure that the you pad out your 1024x576 resolution with
enough lines in the front/back porches, so that the product of the total number of pixels [ including the porches ]
and the refresh rate; is equal to one of the available pixel clocks [ RAMDAC ] on your video card.
The process is a bit complicated for a forum posting.
Originally posted by jmschnur Could some one go over the correct way to get the new resolution. Every time I do this the reboot gives me a blank screen and the only out has been for me to rescue with a recent disk image. I want to use the 1024x576 with the HT1000 in the 16:9 display mode. |
