I have a Zenith C27V36 HDTV and I've been trying to get the DVI output to work perfectly with this tv, with little results.. My first question is, why does the settings in powerstrip I've made here for 960x540 work, but when I try to use the same number of total lines of resolution to display 1280x720, it shows nothing? The settings that work are:
Generic timing details for 960x540:
HFP=216 HSW=48 HBP=368 kHz=45 VFP=84 VSW=30 VBP=96 Hz=60
Linux modeline parameters:
"960x540" 71.375 960 1176 1224 1592 540 624 654 750 -hsync –vsync
(I don't have the powerstrip specific settings b/c those are the ones I was trying to modify)
The settings that use the same total resolution, but different active resolutions are:
PowerStrip timing parameters:
1280x720=1280, 116,40,116,720,10,10,10,71375,2310
but they don't work..
Second, I would like to know if there is a place where I can find out about any service menus for this set, and how to enter such a menu. Thanks for any info..
