Status
Not open for further replies.
1 - 3 of 3 Posts
Hi
Any chance someone managed to make a 1368 x 768 @ 56Hz resolution with this card §
I tried with Powerstrip but after reboot it seems the card will not accept any 1368 x 768 resolution ...
I need it for the Sony 11 HT !!!
Any help is welcome.
Cedric
Some troubleshooting steps:
1. Try creating 960x540, just to make sure the driver is accepting custom resolutions. If it doesn't work, try a different driver.
2. If it does work, check Windows Display properties > Settings, and make sure you can select a resolution higher than 1368x768 (e.g., 1600x1200). If you cannot, change your monitor type so that you can get 1600x1200.
3. If you can select 1600x1200, and 1368x768 continues not to work, try 1360x768 or 1368x766 instead of 1368x768, and see if it holds. Drivers often seem to have problems with a specific resolution, where selecting a resolution that's a notch higher or lower will work.
1 - 3 of 3 Posts
Status
