1 - 10 of 10 Posts
I installed PS for my ATI X1950Pro that is hooked up to my Pioneer PDP-5070 thru a DVI to HDMI cable.
Here's my problem:
I cannot get the advance timing options to work.
I can see the tab but it's grayed out.
I uninstalled and re-installed twice. No luck.
I have my ATI Catalyst software installed. Do I need to uninstall it for it to work?
I know the card supports customer resolutions because the Catalyst software allows for me to do this. The problem with that software is I cannot center the picture using the software. For some reason the option to adjust position is not available when the monitor is hooked up thru the DVI to HDMI cable. It's there when I hook it to the VGA cable. I thought that maybe Powerstrip would solve my problem.
Thanks for any help.
Don't uninstall your videocard drivers! PowerStrip is *not* a driver. It's a utility that uses (rather auto-detects) the limits imposed by your videocard drivers... so that stuff that might not work will trigger warning msgs, for instance.
So it's of no surprise to me that you're seeing the same options blocked off in PowerStrip as they are in the CCC.
You won't be able to reposition the image when on DVI. It's been my experience too. Don't officially know the reason why. It just is. Maybe somebody can enlighten us both.
Discussion Starter · #3 ·
Any idea if this is a limitation of the Plasma or the ATi card?
I'll buy a GeForce 8600GTS video card if it will allow be to center the picture on my plasma via DVI to HDMI.
Discussion Starter · #5 ·
Don't know. I personally don't have 300$ CDN lying around to buy an extra videocard to see what the differences are, but I'm sure some more wealthy/informed people will be able to answer you.
It's not actually laying around.
I just built a HTPC with a 8600GT video card instaled and had the same off set picture you described. I instaled powerstrip and too had the greyed out advance tab. I did all the usual stull and still no advance timing access. I went to Powerstrip tech and found out Powerstrip does not support Nvidia 8800 series cards. I am not sure if the adjustment i found in the Nvidia settings are normal or a part of pure video which i instales, but there is plenty of adjustment in there.
Good Luck Dave
I've used Powerstrip quite successfully with an x1950 Pro, specifically the advanced timings.
Did you update Powerstrip to the latest version?
Discussion Starter · #9 ·
Yes, I have the latest. I'm not sure why it's acting this way.
I just built a new system after posting this thread. I'm now using a 8600GTS.
I haven't tried anything out yet. Still installing software at this point.
Discussion Starter · #10 ·
Good Luck Dave
So for sure Powerstrip does not support nVidia?
I bought a 8600GTS and I still have the same problem.
1 - 10 of 10 Posts
