I was wondering if any of you have used Powerstrip with a Davis DLX650 to get a 16:9 or 1.85:1 windows desktop.
I can use Powerstrip to get the right resolution, but unfortunately my projector on a resynch gets confused by it, and thinks it's an 800x600 signal. If I start with a 1024x768 resolution, the projector synchs fine, and then if I change to 1024x554, it also synchs fine. The only problem is if I tell the pj to auto-calibrate - it then goes back to an 800x600 view.
I had posted this question to Ashley, and was told that my pj doesn't quite recognize the timings I was giving it - but I didn't get any specifics on how to fix it.
Does anyone have any suggestions? Anyone used powerstrip with this projector?
Thanks in advance!
Mike
Thanks in advance!
Mike
