Status
Not open for further replies.
1 - 5 of 5 Posts
Is there any documentation for the Powerstrip program ?? I just purchased the program this week and have been unable to find a user's guide, or a reference, or any other kind of documentation, save for what you good people have posted in this forum. I am baffled by all of the options available aned have no clue as to how this program works. Can anyone provide a reference ? I have already seen the custom resolution guide posted by Karnis, andm, while I'm sure this is very good information, I am in need of something a little more basic.
-Dennis :confused:
Unfortunately Dennis, if there's any documentation I haven't been able to find it. I'm in the same boat as you trying to get that program to work. I do have one working resolution after a day of pounding my head, but that's it.
What you might try is a search, in this forum, for the type of TV or Proj you're trying to display on. Doing that I was able to find other people with the same setup who had posted there settings and I used that as a starting point.
All I can say is be patient, and keep trying. The smarmy thing really does work, but it ain't so easy to understand.
Post your needs specifically and the guys on this forum can get you through almost any setup.
Be sure to give them your system makeup:
Projector model
Screen Size
Video Card info and processor
DVD software or hardware viewer
Viewing prefence 4:3 or 16:9
Good fortune!
Discussion Starter · #5 ·
OK. I'm trying to set up my HS10 in the native resolution - The Powerstrip timings were given elsewhere in this or another forum, but, what do I do with them?
I am using a Radeon 9700 Pro and Windows XP Pro to connect to the projector.
A step-by-step explanation is what I need. Any help appreciated.
-Dennis
1 - 5 of 5 Posts
Status
