Status
Not open for further replies.
1 - 5 of 5 Posts
I currently own a Denon AVR-5800 receiver which i'm using as a pre-pro. I'm using it with a Sunfire Cinema Grand Signature to power 5 Martin Logan speakers,while the 5800 is powering the side surrounds and the center back surrounds. Is this current setup good enough , or would I get even better performance using a Dedicated pre-pro?
I was thinking about getting Sunfire's Theater Grand III since it's the same brand as the amp. I know that there are other pre-pro's like Anthem and B&K, so I need some input as to which one would sound best with my Martin Logan system. The only problem I have with getting the Anthem is that there are no Anthem dealers in or around my area. So if I have to choose between the Sunfire And B&K, which would be the best choice for my setup?
SV ;)
All of these are great pre/pros. I don't think you can go wrong with any of them. However, I would also like to hear other comments, as they are also on my short list.
I dont think you can go wrong with any of the Pre/Pros mentioned.
My Ref 50 shipped yesterday, and I expect it tomorrow!
Fred
1 - 5 of 5 Posts
Status
