I'd like to put my components "in wall". I'd like to find a tinted glass door in a wooden (or black) frame - doesn't need to be custom, some standard size from a kitchen cabinet should work, but in any case, I can make the hole in the wall fit the door. Problem is I can't find such a thing. I can find doors for the kitchen but the not with tinted glass. Browsing the forum I found a place that will make tinted, temperd glass (should be perfect) but I can't find an empty door frame.
Any suggestions where I can find a door with the frame and tinted glass? Failing that where I can find the door with the frame and no glass?
I know I could get the door with clear glass and just replace it but if I could find something without the glass or with the proper glass that would be ideal.
Brian
Brian
