I'd suggest looking at the outlaw line. I do not have first-hand experience, but have heard nothing but positive reviews. www.outlawaudio.com
Originally posted by efritz I'd suggest looking at the outlaw line. I do not have first-hand experience, but have heard nothing but positive reviews. www.outlawaudio.com |
any other to consider? |
Originally posted by cubesys RS-232 is a must for my system integration. |
Originally posted by DMF I'm interested. What do you expect the RS-232 port to provide? A control interface? Firmware upgrade capability? "RS-232" is simply a connector and electrical interface specification. There's nothing in the spec about what it's supposed to interface to. |
Originally posted by Cliff Watson The P-965/A-965 combo has a street price that is about the same as the Cary Cinema 6 MSRP. |
Originally posted by HTCrazy In this case, you really get what you pay for. |
Originally posted by Cliff Watson †The Outlaw, Rotel, and Sherwood while being great pieces of equipment are considered entry level by some and should be compared to each other because they're at similar pricepoints and features.†Thank you! Thank you! Thank you! For driving my point home to StereoJeff that the Newcastle is under-priced for the quality it provides and will be talked down by the penis-measuring folks. |
