I've got an old Pioneer Elite receiver that doesn't decode the latest BluRay audio codecs. I've been wanting to upgrade for quite awhile and should be able to soon. I have a 3-channel amp (Odyssey) already, and I'm only going to be running a 5.1 system, so I'm thinking it might be worth it to put my money toward a pre/pro vs. a receiver. (I'll buy an inexpensive 2-channel amp for the rears) The features I'm looking for are:
* Room correction - I've not been real impressed with the MCACC on the Pioneer Elite, but it is very old. I've heard good things about Audyssey's latest and even better about Anthem's.
* Video upscaling - I wasn't really thinking about this since I have an Oppo 93 which handles dads, and I watch mainly high def contact through DirecTV. But I've heard that good upscaling can improve even the high def DirecTV material. Is that the case? To the degree it is, then video upscaling is important?
* Sound quality - My main critical audio listening is through a modded Squeezebox. I stream FLAC files to it. I want something with good DACs.
I'm NOT interested in 3D video or the ability to stream internet music or audio files. I'm looking to pay around $1500 ($1000 would be great; $2000 would have to really be something that is worth the extra money). I'm totally fine with looking for a used model if it meets the above criteria.
ALSO, I don't know that it is a given that a pre/pro would outperform a receiver. If there are some receivers out there you think I should consider, I'm not opposed. ... And, I'm not set on these brands, but these are the ones I'm "fond" of: Integra, Anthem, Marantz, NAD, maybe Onkyo or Denon.
