I've got the older-style CM 4221 (4-bay) antenna, mounted in my attic, aimed at an antenna farm 31 miles away, and it has always worked fine, with no channel drop outs, including my two high VHF channels (9 and 11).
I've now added some splitters and additional RG6 quad shield cable so I could connect two other TVs to the antenna. There are two two-way splitters and the longest run of cable to a TV is about 80 feet. I've installed a Winegard AP-8700 preamp to make up for the signal loss due to the splitters and added cable length.
Now, even though they worked fine before for over a year, my two high-VHF channels drop out about every 4 days, usually in the evening for a couple hours. This happens on all TVs, on all the different cable runs.
I know my CM 4221 antenna is mainly a UHF antenna, but it always worked fine for me for high-VHF channels, until I added the splitters and preamp.
I double checked the voltage runs along the preamp, and everything seems to be working fine, and the preamp does boost the signal strength of each channel, usually by 2 or 3 bars out of 10. But could the preamp be contributing to my channel 9 and 11 stations to drop out?
Another question: Since my antenna is in the attic and not on a mast, I mounted the preamp at the bottom of the antenna, on the pole where it would go into a mast. This couldn't be causing any electrical interference on the antenna, could it?
Any advice on how to fix this? I know putting the antenna on the roof would be better, or adding a high-VHF antenna would help, but since it worked before, I was wondering if the culprit is the preamp?
