1 - 1 of 1 Posts
Discussion Starter #1
Hello ALL,
Okay i would like to experiment and upgrade the opamps.
I want something that's gonna give me the most crystal clear sound & clean sound with the best bass. I hope it will have delicate highs with a deep bottom end bass and good separation of instruments and brings the vocals a little forward so they are not so recessed behind the instruments i guess. I am not audiophile but i am learning
the AD797AR op amp its a preamp ,Analog Device's AD797 is a very low noise, low distortion operational amplifier ideal for use as a preamplifier. You can enjoy more enriched sound with elastic lows and delicate highs.
OPA637 the powerful and high-resolution sound which would complement rock or vocal music ,
AD8620BR Analog Device's 8620BR provides amplified sound which you would hear in a large open theater, with superb resolution and improvement on both high & low frequencies.
Texas Instrument's OPA627 provides well-balanced and smooth sound performance. Compared to the current OPAMPs (LM4562, OPA2134), the OPA627 gives a soft, rich and refined sound that is easy to the ear. OPA627 offers relatively deeper sound with more gravity, with more bass sound, which is suitable for the classic-music type.
I mostly use headphones darthbeyer ftw....
__________________
current- beyer dt990 rare Bolivian rosewood v3 darth beyers
headphones ive tried darthbeyers,dennon2k,hd600,dt770/80ohm,hd280pro.
xfi extreme music card & X-FI PRELUDE logitechz5500 with pc as source.
music in order rock,electronic,everything else except country.
1 - 1 of 1 Posts
