MeddlingKids -
Unfortnately, there is only one thing that will block low frequency sounds - mass. Padding, acoustical foam, insultation and the like are good for absorbing high frequencies, but will have almost no effect on low bass frequencies.
In years past, recording studios actually used lead sheeting to block low frequency sounds. Often times, dual sand-filled cinderblock walls are used.
A dual wall structure is required at a minimum. This prevents vibrations from the inner wall from being transferred directly to the outer wall. No matter what you do with a single wall, vibrations will be transferred through the wall.
- Jim
- Jim
