Since I have helped people out at work with their systems, etc. My day job got ahold of me to review their plans for a surround system to be used for "dog and pony shows", etc
Well the problem is that this is a 10,000 cu ft room, the budget will be fairly limited.
They have it subcontracted out and the "sub" for the room is a JBL SB2. A 10" slot loaded driver. (see link)
http://www.bhphotovideo.com/bnh/cont...ist&sku=124621
Now on the positive side, it should play at least decently loud for $230 but, the thought of the entire low end being taken care of by a 10" driver (-10 dB at 38Hz) for 10k cuft is a bit much.
I know getting this to reference is an unrealistic goal, so is anywhere near 20 Hz. Reality is that 35Hz should be more than adaquate for the application.
Any ideas?
Any ideas?
