1 - 2 of 2 Posts
I have a new Camry (OK, I know
) with a JBL head unit. I was trying to connect my Sony Nav (NV-U94T) or my phone, but neither worked. When trying to pair, my nav found the JBL but the JBL kept searching, found nothing and gave up. The JBL could not see my cell (Nokia) either. However I was able to pair my Nav with my Nokia, no problem.
Any suggestions?
A trip to the dealer would clear things up, though they may be busy with pedal repairs
My first new car is a 2010 Corolla. :facepalm:
Bluetooth is often a painful process. Since you can pair those two electronics together I assume you understand the general scheme of things, but it never hurts to be sure. Did you make sure that if one is set to find, the other is set to discovery mode? Does your car manual have information on pairing? Perhaps there is a specific order that the JBL prefers, which you haven't quite hit on yet.
Here is a link with some bluetooth-JBL-camry woes. Perhaps something useful can be located in there.
http://townhall.edmunds.com/direct/view/.f0bc698/410
1 - 2 of 2 Posts
