1 - 2 of 2 Posts
I'm having some problems connecting components to my tv through hdmi. I just built a htpc and when i go through to hdmi the screen goes red and constantly loses and gains a connection. I remember intially having problems with my dvr too when i bought the tv but i brushed them off and connected it through component. The hdmi works fine with my xbox 360 so i'm not sure why these devices wont work.
If the settings are correct (hdmi) sounds like a mechanical issue (cable or port). As you built the htpc, you should be able to test these items.
As a jfyi, a simple process of elimination will test the plasma port and cable: run a bd or dvd player through this same cable and port. If it handshakes and works properly, you now know it is your htpc port (or htpc). Good luck.
1 - 2 of 2 Posts
