I'm trying to connect my desktop computer to HDTV to watch movies but there is no signal. Someone time it would show the windows boot screen, then when it goes into the desktop screen the signal is gone. Sometimes there would be no signal at all from the start.
I'm connecting to the TV from gtx580 videocard through the DVI port using a HDMI adapter. The HDMI cable is 25FT and is connected to the TV's hdmi port. I have also tried setting my screen to 1920X1080 to match the TV, but it still does not work.
I'm not sure if my dvi to hdmi adapter is the problem or I should have a different setting in the computer that I should change.
Also, I have a laptop that I would connect to TV through hdmi to hdmi and that would work on the TV. The only problem is the laptop's resolution is only 1300x780.
Any help would appreciated. Thank you.
DVI to HDMI adapter that i'm using.
http://www.microcenter.com/single_product_results.phtml?product_id=0355991
25FT HDMI Cable
http://www.amazon.com/Mediabridge-Ultra-Series-Certified-Available/dp/B0031TRZX2/ref=sr_1_2?ie=UTF8&qid=1339949751&sr=8-2&keywords=25+ft+hdmi+cable
25FT HDMI Cable
