Status
Not open for further replies.
1 - 1 of 1 Posts
up until this point, I have never had any problems transferring shows using dvarchive, but the other day, the following happened:
I have 3 episodes of the simpsons recorded on my rtv, all 3 shows are titled, the simpsons, with the same default description for all 3, Homer and Marge Simpson raise, Bart, Lisa, etc...
Since the 3 different episodes are labeled identically, I cannot copy them all into the same directory, so I created a separate folder for each ep., then qued all 3 eps to download. Later, when I checked on the progress, the first episode transferred correctly, but the remaining 2 eps were only 0-byte files in the proper folders...
Is it even possible to que multiple shows to transfer into different folders?
1 - 1 of 1 Posts
Status
