1 - 2 of 2 Posts
I just got the GGW-H20L and am having trouble trying to get it to install on my Hp a6320n computer. I turn off the computer, then connect the drive to a SATA port on my mother board, hook up the power cord. However, when I turn the computer on and windows loads, the computer crashes and I get a blue screen saying a problem occured with hardware and then it says something about dumping memory and then the computer reboots. This loop keeps going until I unhook the drive. I have tried a sata port that I was using for an extra hard drive. Would it help if I got a PCI Sata card and installed that. I am using AMD processor.
Try the HTPC section of the forum. You'll have more luck..
Asking this question here will only garner responses like, " Buy a standalone Blu Ray player and forget the hassles".
1 - 2 of 2 Posts
