Status
Not open for further replies.
1 - 7 of 7 Posts
:confused:Hey everyone, appologies if the answer is somewhere in the forum but I couldn't find it.
My problem...
I'm trying to use my flat panel and HDTV on my Sapphire Radeon 9500. All I want to do is run video on the secondary display so I can do other things on the primary. Here's the kill, DVD's and DivX's will play happily on the secondary display but mpeg2 files will only display a black box (audio plays) on the secondary (they play fine on the primary - I've made my HDTV the primary temporarlity as a work-around but that's not an acceptable solution).
The mpg files are made by my WinTV 250, I'm running WinXP, DX9, Radeon 9500, Sonic or WinDVD (both have same issue). I primarily play the files in Zoom but the native Sonic/WinDVD players do the same thing (no secondary). I tried VMR9 but everything crashes when I hit play.
I'm really at a loss since DVD's (mpeg2) will play on either display fine but my recorded files (also mpeg2) won't. H*** I can even play DVD's on both displays at the same time (Zoom and WinDVD).
This is highly frustrating so any help would be greatly appreciated.
Chad
unfortionatly, using hdtv as pri is the only way to do it. something about overlay i think
Discussion Starter · #3 ·
Anybody?
As I said, some video will play fine (DVD's, DivX's) but straight .mpg mpeg2 files don't play on my secondary display (doesn't matter which display I set as secondary). I don't use powerstrip since my "HDTV" is basically a 36" 800x600 monitor. Overlay, VMR, doen't make a difference. Can't get VMR9 to work.
Thanks again,
Chad
I have had this problem a few times with my ATI 7000. I remember certain files would display, and other wouldn't. I fixed it by picking the display option that would mirror the primary's display on the secondary. I'm not sure that will help you because I don't know which drivers you are using, but it's work a look!
Discussion Starter · #5 ·
L1st3r,
I already looked at that, I'm running the Catalyst 3.2, but I can't find the Theater Mode (display video on primary full-screen on secondary) anywhere in the ATI CP, don't know if I'm and idiot or if that feature was removed.
Chad
Ummm, yea, I couldn't find it either. So I went ahead and installed the older control panel as well. It doesn't overwrite any of the drivers that I could tell, and worked fine in my system. THe file you are lookin for is:
CONTROL-PANEL-6-13-10-3027-efg.exe
if you can find that on ATI's site, try it if you're bold. I know it worked for me!
Discussion Starter · #7 ·
L1st3r,
Wow, that's old, like 6 versions back, I don't think I'm going to try anything that old.
Anyway, I found a bandaid (not a solution), it turns out that if I disable DXVA everything will play on the secondary. Something seems wrong with that.
Chad
1 - 7 of 7 Posts
Status
