1 - 3 of 3 Posts
· Registered
I do not have a 4 x 2 hdmi switch yet (coming from monoprice thurs) so I have to manually pull the Plasma output and put in the epson 6100 input to get the signal. When I do this the Directv turns a pinkish color. I can fix the problem by resetting the receiver and I hope that the 4x2 hdmi switch will help. Anyone else have this problem or need more explanation.
· Registered
Manually switching your cable will do strange things like this. Pulling and plugging the cable can also cause you to put stress on the jack and possibly pull it loose from the display circuit board. I'd get that switch asap and stop pulling and plugging your cable.
· Registered
The HDMI ports on pjs don't seem to be as robust as other devices, so I agree that you should avoid that. I have seen what you are describing on another pj when switching (via 4x2) between my computer and DTV, but it was only momentarily, and I have never seen this on the 6100.
1 - 3 of 3 Posts
