Guess I'm more of a noob than I thought - I had been using an Iscan Pro with my 8" crt for the last year and a half, had no problems or real concerns. But all the folks on the CRT board maintain that 480p is not good enough for my CRT.
OK - so I am now trying a Quadscan Pro, and I need you folks to tell me if this is typical scaler behaviour, or if I have a funky Quadscan. Hooked it up, got it to synch, etc, and started going thru the output options.
Problem/question is: I get a different sized picture, displayed in a different location, for each different output. Is this a, "duh" thing, or is this normal?
Like, for some sources I like triple tv, some look better with quad tv; but quad tv is like a foot wider (I was working with a 12' screen back with the Iscan.)
my wife likes XGA - 1024 x 768, and it does look pretty good on my pj, but it is about 2/3 the size of the other res, and is up and to the right on my screen.
if this is normal, I will live with it, and make some custom memory locations for each res - and here is another q, for all you HD and Lumagen owners - do your new gen scalers behave this way?
thanks guys,
thanks guys,
