Just an fyi changing refresh rate to 24hz should make everything skip. At that rate normal stuff on the pc will be pretty much useless. You would only want to set it like that for watching a movie.
As far as the card I can't help you much. Have you tried hooking up just the tv and not any monitor.
I have an xfx 5770 (reference cooler) running dual monitors and all is well.
If you never see those lines on the tv with any other source then it does seem to be the gpu.
