I just got the JVC 30K D-VHS VCR and a Samsung SIR-T165 set top box. The Samsung box can control and record into the JVC D-VHS VCR. This works, but the Samsung box looses scheduled programs after it has been turned off for a while. Has anyone else had problems with this set up? If I put programs into the program schedule that start within a few minutes, the Samsung will power itself on, power on the VCR, set it to the proper Ilink/IEEE1394 input and start the VCR in record mode. It will stop the VCR and power everything off after the program is over. However, if the box is left off for longer then 15 minutes or so, and you go back to check the list of programs to be recorded, it will be empty. Does anyone have any suggestions for what is causing this and what to do to fix it? Nothing else is lost as far as settings when the box is powered off except for the schedule of programs to be recorded. The Samsung box must be powered off in order for it to perform this recording function.
Does anyone else here have a similar set up? If so, what is your experience with it? Has it been reliable when it comes to recording programs on the VCR?
