Hi all,
I recently purchased a new receiver with a set of speakers (Onkyo TX-SR507 with Tannoy HTS-200 speakers).
Everything is set-up properly, and it sounds mighty fine.
However, I have 2 unanswered questions.
1. My volume only indicates from 0-79, instead of a negative scale going from 0 dB down. I would like to know, maybe there are some other Onkyo owners out there, at what level am I at or close to reference level for movies?
2. How loud can I push the volume without putting my speakers/amp at risk? I already listen to it at reasonably loud levels, but sometimes, I would like to "push it to the pegs".
The specs for my amp are the following:
Rated Output Power:
80 watts minimum continuous power
per channel, 8 ohm loads, 2 channels
driven from 20Hz to 20kHz, with a
maximum total harmonic distortion of
0.08% (FTC)
90 watts minimum continuous power
driven at 1kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
100 watts minimum continuous power
per channel, 6 ohm loads, 2 channels
harmonic distortion of 0.1% (FTC)
Maximum Output Power
5 ch × 160 W at 6 ohms, 1kHz, 1 ch
driven (JEITA)
Dynamic Power
180 W (3Ω, Front)
160 W (4Ω, Front)
100 W (8Ω, Front)
My speakers specs:
Center and satellite:
Recommended amplifier power 25 - 100 Watts
Maximum Sensitivity (2.83Volts @ 1m) 87dB
Normal impedance Centre 8 ohm Satellite 6 ohm
TOWER SPEAKER
Maximum Sensitivity (2.83Volts @ 1m) 88dB
Nominal impedance 6 ohm
I get mixed up with the Rated Output Power, Maximum Output Power, Dynamic Power. Can anybody help me making sense out of this?
Many thanks
Rated Output Power:
0.08% (FTC)
driven (JEITA)
Dynamic Power
180 W (3Ω, Front)
160 W (4Ω, Front)
100 W (8Ω, Front)
My speakers specs:
TOWER SPEAKER
Many thanks
