due to size and layout conditions in my room, I may have to have a long run to the amp from the HTPC (using delta 410 card for digital out).
I want to keep the video run as short as possible, so that means the pc would be relatively close to the pj (computer on floor and to the side and pj on ceiling).
That would have me putting the amp/processor under the screen at the front of the room (no room at the back w/ seating area and the room is only ~10 wide, so w/ the sub on the side wall, there is not really any room there either), so my digital coax run would be about 20ft by the time I tucked the wire into the corners.
Would such a long run cause sync problems, or does the audio card even put out a strong enough signal to travel that distance w/o level drop?
If anyone is using extra long (20ft or more) video (VGA or VGA to rgb breakout) or digital coax w/o any adverse side effects, I'd love to hear about it....otherwise I need to re-think my room layout.
