  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Problem w/MKV in Vista MCE not playing in widescreen
1301 Views 1 Reply 2 Participants Last post by  jrwalte
I just re-built my HTPC and I'm having some issues playing MKV files. When I launch the MKV it starts up scrunched into almost to a 4:3 aspect ratio, if I restore or minimize MCE it forces it to the correct aspect and plays fine from there. This is only happening with MKV files and it happens to all MKV files regardless of their aspect. My HTPC is configured as follows:
Hardware
AMD64 X2 6000+
ATI 2600HD Pro 512MB (HDMI dongle)
4GB RAM
Panasonic TH-58Z700U
Software/OS/Codecs
Vista Ultimate w/My Movies 2.42
PowerDVD 7.3(Ultra) lastest Service Pack
Haali Media Splitter - 1.7.401.3
ATI Catalyst 07.12 (lastest build)
Spdifer 0.2a
No other software installed
I've installed FFDShow via the Vista Codec Pack and it resolved this issue, but 1080p/DTS playback wasn't as smooth and would cut in/out loose audio sync etc. I would prefer to keep the existing software config as it's the smoothest I've found so far. Any suggestions would be appreciated.
See less See more
1 - 2 of 2 Posts
I have this exact problem. Did you find a resolution?
1 - 2 of 2 Posts
