You haven't told us what happens when you use component (not composite) instead of HDMI.
Originally Posted by cb2367 /forum/post/20815886
At this point, I have no cable TV at all using composite cables or connecting the coax to the TV. If I leave everything as is, all I get is audio. I switched out the box in the hopes that would fix the problem, but it didn't. The soonest I can get a cable tech to come out is next week, but in the meantime, what else can I do? Would changing the HDMI cable work? Subsequent refresh signals have not brought the box back online. It seems to be a coincidence that the cable box stopped working after the latest refresh was sent.![]()
Originally Posted by cb2367 /forum/post/0
Well, after a box exchange and several calls to Time Warner Tech Support, I got a Time Warner representative on Twitter that provided some helpful information on how to fix the problem I had. It seems that the display settings checked were 1080i, 480p, and 480i. The box was configured to always tune to an SD channel when turned on. I don't know what settings were in place for the display prior to changing the box, but after de-selecting 480p and 480i, I was able to once again view all channels. I was uanble to get the advanced settings menu up on the box by pressing guide/info, so my guess is there must be some other button combination.
Another thing I noticed is that as far as the sound display on the receiver, it used to say CBL/SAT. Now every channel is CBL PLII Movie. I have to keep the sub off because on CBL/SAT and CBL PLII Movie, there is a lot of bass coming through the sub.
