I just had Dish with 811 installed yesterday. The HD channels are great, but I have a problem with the SD channels:
The 811 is connected to a Denon AVR-3803 via component connection, and from there to my Mitsubishi WS-65613 (I route all the video through the receiver so as to only have one connection to the TV, since the 3803 upconverts to component). Since the signal coming into the Mits is 1080i (811 upconverts the non-HD channels to 1080i), my only stretch options are "Standard" which results in pillarboxing (as one would expect), and "Wide Expand" which should force the image to fill the entire 16:9 screen. The problem is that the "Wide Expand" does not expand the signal far enough. I still end up with 1-inch black pillars left and right; I'm concerned with burn-in issues down the line.
While the 811 has an option to "adjust" the position left-to-right, there is no zoom or sizing options, nor am I aware of any similar options on the Mits.
Any ideas?
Thanks in advance,
-Dan
Any ideas?
Thanks in advance,
-Dan
