I used the supplied software that came with the unit to download an image to it (like a splash screen when the unit first turns on, before a signal is detected). Now, however, when I turn the unit back on, the bulb shines for about 5 seconds, then dims out completely. At that point it freezes. I get no picture, no bulb activity and I can't turn it off unless I turn the power off from the power strip the unit is plugged into. I have only had this unit for a couple months and it has served me well up until this point. If anyone has any ideas or thoughts they are much appreciated. I first thought to buy a replacement bulb, but since the bulb shines when it is first turned on I figured the bulb can't be bad (or at least it hasn't burst).
thanks,
-santos
thanks,
-santos
