1 - 7 of 7 Posts
· Registered
I have a Lepai LP-2020A hooked up to 2 Energy C-100 speakers. This then connects to my devices via headphone jack. I have used this setup for quite some time. I recently unplugged it from my surface pro while it was still on, and it made a pop sound. Oh well, I have done this before, no biggy. Now when I try to plug it into my surface pro, and turn it on, it makes a continuous popping sound. Really fast pops. It is not even recognized as being plugged in. I plug it into my other laptop and it is not recognized. I plug it into my phone (Note 3) and it works fine. I have readjusted the cables and switched out the auxiliary cable.
Can anyone tell me what is going on here?
· Banned
Originally Posted by maxpowers5  /t/1517960/problem-with-amp-or-speakers#post_24361539
Own up to the fact that you fried an under $20 power amp and either buy a new one or something better.
· Registered
Discussion Starter · #5 ·
Thank you. So it may be fried. I initially bought the amp because I had the speakers and wire laying around not being used so I put them with my office computer to give a little boost to sound. Not entirely needed, but I enjoy it.
My options would be to get a new one and be more careful when unplugging it. Is there any other way to fix it? Take it apart, replace the component? Put it in the oven...? I know there are tricks and I am asking more for the fact that I am curious about electronics.
· Registered
You could probably fix it IF you have some electrical skills and maybe some schematic drawings and / or understanding of the circuit layout.
I suspect its either a capacitor or maybe the input "IC" as it is likely some form of low cost "op-amp" IC. IF you have / had access to a scope, you could probably readily find the issue since you can get it to work in one configuration and not in another... thus with a scope you could probe the circuit along the way and see where the difference occurs.
1 - 7 of 7 Posts
