I have a NEC 9PG Xtra and when I have contrast and brightness at their normal settings of contrast 48 and brightness 59 I can see the blue raster lit up all around the image in the blue tube. On the green and red tubes the only visible thing is the image and you can't see the raster. Is my G2 set too high for the blue tube? It appears the blue tube needs to be turned down just a slight bit. Is the G2 control for the blue tube on the board right above the blue tube. I have adjusted it before on a 9PG+ as it was a little thumbscrew right above blue tube. My image does have a blue edge to it. In the White Balance menu option all three tubes are at 50/50 and adjusting the blue doesn't make the rasters edge go away.
Thanks in advance,
Mike
Thanks in advance,
Mike
