1 - 4 of 4 Posts
I have 2 Def Tech Pro 200tl subs in my system. They're hooked up via Y cable from my Yamaha RX-V2600 receiver. Lately I'm having problems getting the subs to turn on properly when starting movies. The signal indicators on the amp aren't lighting up as they should and I either have to unplug the subs from their outlets and plug them back in or reconnect the sub cables going into the LFE inputs. I haven't done anything different to the system for a while and they've always been fine until now. Anyone know what the problem could be? Thanks in advance.
I had the 200tl for awhile and had to connect both the line level and lfe simultaneously with a y cable.In other words 1 cable from reciever to the y then the sub.I havent had it for awhile so bare with me here,i hope i explained this correctly.Using the y keeps a signal to the sub.If you can contact chet at def.tech. and he'll help you out.
Originally Posted by mskeezer /forum/post/0
I think I got ya. I'll give that a try. It's weird, though. I've never had a problem with the LFE input before. I appreciate the help.
Let me know if it worked out for you.
1 - 4 of 4 Posts
