ok i work at an assisted living facility as a nurse but i usually do the electronic stuff too. so heres my problem WAY before i started they made a cable system that consisted of 9 dtv boxes (all of which only get one channel (SUCKS)) and an arial antenna (needs changed over to digital) so they purchased 4 digital boxes. The only problem is the BOX they have as part of the "cable system" wont accept the digital box because it doesnt register as on channel 3 or 4. i thought about a rf modulator but also has to be on either channel 3 or 4. so.... i the only idea i have is to use the rca's but there are no rca inputs on the BOX (again not digital converter) so im th im thinking maybe a way to use the rca output on the digital converter and change it into coax i belive this would work since rca outputs are not channel specific
i hope this makes sence i would like to figure this out any ideas are appriciated if you have questions please ask
THANKS
DRUNKEN_TIGER
THANKS
DRUNKEN_TIGER
