1 - 7 of 7 Posts
here is the basic rundown
i have comcast basic cable (along with the basic it comes with the abc, nbc, fox and cbs in HD)
tv is 47lg70
for some reason my cadtv channel 13 CBS is no longer working, it just tells me no signal
i can still get it OTA but its real herky jerky sometimes
any ideas?
is is possible that your local Comcast and CBS are having some sort of dispute?
Or is is possible that the CBS HD broadcasts are from distance not normally available easily in your location via an OTA tuner and therfore Comcast is under not obligation to provide them unencrypted?
Check the HDTV local forum for your location you may find an explanation there.
What is your Zipcode? We may be able to help you out better if we know that.
Discussion Starter · #5 ·
i guess thats possible, but iv had the channel before
zip code is 87110, its Albuquerque, NM so its a fairly large city
Perhaps there's a PSIP problem or incompatibility with your TV and CBS is being mapped to the "real" QAM channel (I.E. channel 88-5 or 110-1, etc.).
Have you tried "surfing" after a scan to verify that your local CBS
cable channel isn't showing up elsewhere?
1 - 7 of 7 Posts
