I am using my Wii on a computer monitor, as such I am sitting "computer" distance away on a computer desk. I can plop my sensor bar bar on top of my monitor, which by far gives me the best results, or under it even under the keyboard tray if I sit far enough away, problem is its a monitor so I really don't want to sit that far away eventhough I will if I must.
Anyway, I was wondering if there is any solutions to using a wii sensor bar 2-3(like 2.5 estimated) feet away from the actual controller, perhaps I could make my own sensor bar to compensate for distance, problem is I don't know how spread apart I would need to spread the IR sensors for this. Anyway heres a picture of my setup~ not trying to brag photo here just to give you an idea of how it is and suggestions that can be made. (Problem is it gets jumpy at small tilts in the wrong way sitting as close as I do and at normal rest position which was fine when using my TV sitting from far away, ends up pushign the cursor all the way down to the edge of the screen, overdoing it. Tested in Okami~
Anyway thanks ina dvance for any advice, in the image between the monitor and edge of the desk is 1 feet, between the monitor and my chair almost exactly 2 feet which is where I play~
