1 - 5 of 5 Posts
I have an old Energy AS-90 12" powered sub
it was working fine then all of asudden it started making a strang sound
like wind
it doesnt mater where I put the knobs it make the same noise you louder no quiter
something wrong with the amp??
what do you call the knobs? where can I buy new ones? in Toronto
thanks
Discussion Starter · #2 ·
I thing I might order some Potentiometers and solder those in and see how that goes
anyone?
Might be best to contact Energy and ask them for an opinion. I'll bet you are not the first to have this problem.
Discussion Starter · #4 ·
I saw some different posts on the net with similar problem and it was the pan pots
so what I did was remove the plate amp and remove the cover so I could get at the pots from the front an back
I spayed a small amount of brake dust cleaner(Auto) and went at them with a Q-tip in lots of rubbing alcohol moving the knob back and forth
they really freeed up, I didnt relize that thay had gotten really really stiff
works great now
let see how long it lasts
1 - 5 of 5 Posts
