Status
Not open for further replies.
1 - 7 of 7 Posts
Hello,
I have the Philips 30PW850H HDTV and a Sanyo DVD Player. The player is progressive scan and when in progressive mode, my TV does not allow you to change the format (eg. 16:9, 4:3, zoom 16:9 etc.). Now i have several older dvd's that are fullscreen and when i play them the picture is screcthed horizontally and I cannot change the TV's format. What I was wondering, is it the dvd players job to add black bars on the side of fullscreen movies with the player is set to display on a 16:9 tv just as it adds black bars on a 16:9 movie when it is set to display on a 4:3 tv? I acutally am borrowing the sanyo player and was thinking of buying the Pioneer DV-563A. Any suggestions and help on this problem would be appreciated. Thanks
Ryan
P.S. just so everyone know, I prefer widescreen dvd's but several older movies are only 4:3.
Banned
Some DVD player models do have that window-box feature for 4:3 titles on 16:9 displays, but most don't. The JVC models have this feature and the new Mitsubishi models do too. You should switch to one of these other DVD models for a set that locks to FULL mode in 480p or else you need to switch to interlaced mode for 4:3 and non-anamorphic titles - that sucks. The new model JVC XV-N40BK has this feature and has a $20 rebate offer now, so its available as low as $65 online with the rebate, an excellent bargain with lots of features including automatic window-box of 4:3 titles for 16:9 display.
Discussion Starter · #3 ·
Good suggestion, I'll have to look into it. The reason that I had my eye on that Pioneer is that it has support for SACD, DVD-Audio, as well as built in decoders for DTS and Dolby Digital. My receiver only decodes DD, so having a DVD with 5.1 analog out is very attractive. Since my only fullscreen movies are Chirstmas Vacation and Its a Wonderful Life, I guess I could just use my PS2 in interlace mode for those since they (especially Its a Wonderful Life) would not benefit from the progressive out. It seems that a dvd player with the option for a 16:9 tv should also have the option of how you want the 4:3 movie to be played.
Thanks for the reply.
Ryan
Discussion Starter · #6 ·
Well, I have a solution. I am currently using my HTPC with a radeon 9700 pro with the ATI dongle to output 1080i resolutions. I then use the dvd software to scale the dvd to 1920x960i which has given me the best picture i have seen from a dvd. Now since i am using a software player, i have full control over the aspect ratio of the dvd even thought my tv set does not allow it. Thanks for all the suggestions thought.
Ryan
To answer this question: No, this is a design flaw in the television, not the DVD player. It should not be the DVD player's job to add bars to the sides of 4:3 content. However, so many televisions are afflicted with this stupid design flaw that some DVD players do offer the windowboxing feature in order to get around it. But most DVD players do not.
If you own a DVD player that does not offer a 4:3 windowboxing mode, the only way to get around this problem is to disable progressive scanning on non-anamorphic discs. Then turn it back on when watching anamorphically-enhanced widescreen discs.
1 - 7 of 7 Posts
Status
